- May 13, 2000
- Cape Girardeau, MO
- 94 Sport 4x4
Hello, maybe some you guys can point me in the right direction here. My normally reliable truck has started buckin up on me in the last few days.
A few days ago I was on a trip and the CEL came on, and truck ran rough. After I got home I ran the codes and it showed 177, which is O2 sensor rich. Ok, O2 going out, I can handle that.
But now, today I was driving and my truck's engine died. It happened twice in about 20 minutes of driving, and in both cases I was moving at typical traffic speed (30-40 mph). Luckily I was able to restart the vehicle after trying a little. I checked for loose plug wires, loose battery cable, alternator, etc. but all is good. I thought maybe clogged fuel filter. hmm. It showed CEL, so again tonight I ran the codes, since I suspected a new code because it never died before. This time it showed 177 from before but also 543, which indicates open circuit between the battery and PCM. Is this a fuel pump relay going bad?
The O2s I will change, they're due anyway. But I'm not sure if I'm barking up the wrong tree on the fuel pump relay. I know how a bad FPR can foul O2s. Maybe it's the FPR? Maybe once I change the O2s I'll be ok? Can a bad O2 cause the engine to die? Can a bad O2 screw up the fuel pump relay?
