Engine dies when shifting into reverse... | Ford Explorer Forums
jeff4912
Seattle, Wa
2003 Ford Explorer 4WD
'03 Explorer 4.0, engine idles very smoothly and drives very smoothly.
However, when coming to a stop and taking it out of drive and putting it into reverse, engine will sometimes stumble or even stall.
Only happens occasionally though.
I have a clean air filter, new PCV valve, cleaned the MAF.
Connected my code scanner to the Explorer and the STFT (short term fuel trim) numbers were well within parameters (-2.3 upto +1.3%).
That would lead me to believe that it is not a vacuum leak.
No DTC's were in the scanner.
Same issue, jumping on the reverse/stumble bandwagon.
