engine noise | Ford Explorer Forums
engine noise
green97
Olivehurst, California
'97 Explorer XLT
I have a '96 EX 4.0 auto engine squeals at start up then goes away, but if i turn on air starts again,at low rpm, if i turn on wipers, defrost, rear window wiper lights dim starts squealing and never stops until you turn all off lights go bright stops squealin and runs fine
also I replaced tensioner two motorcraft belts and one gatorback still squeals, only starts squealin when i turn on air or defrost:scratch:
Have you checked the battery voltage with a volt meter before you start your truck? Low voltage causing a heavy load on the alternator is my guess, since you have changed the belts. You are sure the belts are not too long, causing the tensioner to bottom out without not enough tension aren't you?
:thumbsup:yes gatorback was 1/4 smaller was tight will check battery next, thanx
:eek: checked battery 13.27 motor off, started up and went to 14.47 and then as high as 19.10
A battery should never be above 16Volts for Charging, I would take off the alternator and get it tested, or just replace it.
:thumbsup:plan on replacing alt friday , thanks:D
Well, just to be safe, check it first. No sense in replacing it if it is not the problem. you may even be able to just replace he part that is wrong with it, instead of buying a new $150 Alternator. With time the regulators tend to go bad, and leak A current int the battery, which can ruin a lot.
