1997 sohc xlt ford australia has replaced rear engine seal three times in two years but oil leak has not gone , what could it be ? it leaks between the motor and gearbox the slump gasket has been replaced
I though I had a leak at the rear main seal before I found ou that it was really the lower intake manifold.. I would check that to make sure it is not leaking..
If you find out where the leak is definately coming from, please let me know. I just had the truck in the shop for an oil leak, and they are quoting me approx $400 to change the rear main seal.......
