Engine or tranny? | Ford Explorer Forums
Engine or tranny?
JamesRolls5.0
New York
1999 ford explorer 5.0
Okay so my rear main seal is leaking..
Like between the engine and tranny
Its starting to practically run oil like water
Im prolly doing the work myself
Can i just drop te tranny and change it with the engine still in the truck?
Or should i pull the 5.0 out and do it?
Normally for a rear main seal the engine is left in and the tranny taken out.
drop the trans, and you have tones of room
thanks a ton for that pic i actually just did the job and so far so good
no leaks
you don't know how relieved i am as this was my first big engine job
i also threw some lucas engine oil stop leak to be safe
( i had tried this product before but it only slowed the leak to almost nothing but the idea of a leak still tortured my mind )
Hey James
My 2000 EB (5.0) has a pretty good oil leak (from the rear main) that I'm getting ready to fix. Thinking I may do it @ the next oil change. Already knew the transfer case & tranny will need to come out to access & fix. I've pulled many a tranny's out in my day, but they were all manuals. This will be my first auto tranny, shouldn't be much different?? Anyhow, I was wondering how long it took you to do the job??
Thanks!!
