deamon3
- July 27, 2008
- Wisconsin
- 94 Eddie Bauer
The engine itself smokes on my 94 ex. If the car is just idling or driving around slowly it's perfectly fine.
But if I take it up to 55 it'll run and drive fine but when I come to a stop and open the hood there just tons of smoke coming from the lower area of the engine.
I THINK , it's oil burning off the side/bottom of the engine because it's very wet underneath it. The car has oil in it , there's plenty of coolant and it's not overheating. There's no warning lights on the dash and the oil pressure is reading ok.
If I put my hand down there I can feel a small exhaust leak but nothing too bad.
I'm worried though that maybe the engine itself is burning something when I go to higher speeds. Because surely the engine temp wouldn't change and burn oil off the side of the engine when moving vs when sitting.
It starts runs and drives fine it just smokes after you try to drive fast , also the smoke is white not blue.
