IN2FORD
- October 9, 2003
- Cookeville, TN
- 1996 Explorer Bullitt
These two problems only happen when the outside temp is above 55 degrees.
Problem #1) I can be sitting at a stop light for a couple of minutes and the engine dies...just like someone shut it off. I have cleaned the IAC, recent tune up, Seafoam, and cleaned the MAS. Any other ideas?? Could the fuel pressure reg. be associated with this, or fuel pump, or a intermittently bad IAC...I am lost on this one. No check engine lights and it is setting no code.
Problem#2) Again when it is warm outside, I am getting a chirping sound from under neath the truck. It has something to do with something rotating. IT happens from 30mph to a stop. I have replaced the exculder seals, but it did not help. Now what....is it u-joints or .....
Give me some help if you can...this kind of stuff drives me nuts trying to figure it out!
