Hi, I wanted to provide some insight if need to replace your engine. I successfully swapped my 2011 explorer 3.5 NA with a 3.7NA from a 2016 PIU Explorer. After lengthy research of the 3.7 the only difference is the bore size, to give it more power. The ECU, injectors, coilpacks, fuel rails and intake is the same as a 3.5. Therefore, it was a direct swap with very minimal change. The changes would be the same if you swapped a 2011 3.5 NA with a later year 3.5 NA.
Use your existing motor harness
The ECU doesn't have to be changed or re-tuned
You do not have to change injectors or coil packs
You CANNOT use a 3.7 from a F150, Mustang or Transit van (the blocks are different)
You CAN pull the engine from the top of the engine bay.
If you use your earlier year exhaust manifolds, you have to move the studs to match the correct pattern.
You have to swap 2 cam sensors if you have older 3.5, to fit your motor harness
You have to cap off the under intake coolant line ( later year 3.5 and 3.7's have this)
Hope this helps if you need replace an engine and are looking for a little bit more power.
I also wonder now if all modifications for a 3.7NA (f150s and Mustangs) will directly work with 3.5 NA's explorer (ie superchargers, tuners, etc)
