puzzaa
- October 9, 2016
- Maryland
- 2000 Explorer
Since I had my transmission swapped from a donor 2000 explorer 4.0 SOHC into mine, Ive decided to swap the engine as well.
My current engine is coming up on 240k, the parts truck has 140k miles.
I have no problems with my current engine, however I do get terrible gas mileage and im just waiting for the timing chain cassettes to break because they have never been replaced.
I would like to swap the lower mileage engine into it (as it should have less wear and did get better gas mileage when i drove it around).
I have started work on it and everything is ready to go the 140k just has to be lifted out. The 240k engine is still in and kicking, as its my daily driver but i am starting to hear a rattling noise (which I cant tell if its piston knock or the chains).
Now my question is, when i get the 140k engine out and on my bench what parts should I replace so I wouldn't have to pull the engine again once it is in? Im going to change out the timing components and maybe even do the head gaskets while I am at it. Are there any common wear components that I should look into while the engine is out? I could purchase a rebuild kit, but id like to know if there is anything else that commonly fails on these engines. Also Ford oem part numbers/links would be helpful!
Also would I need a timing tool if I were to replace the timing chains? As far as I know they are all intact and working so I should be able to pull them off and put on the new ones without messing up the timing? I've done belts before with timing marks for alignment but never chains with no marks, so any advice is helpful.
