engine swap/speedo drive gear ? | Ford Explorer Forums
nonhog
Pacific N/W
2000 Explorer sorta
I am on the downside of completing my Explorer powered Volvo swap.
One area I am fighting (there have been many!) is the speedo cable drive.
I don't think the donor 2WD 2000 Explorer had a cable but my question is did it have a drive gear on some years od just snag one off a AOD ?
It now has an AOD tail shaft housing but the ring on the shaft certainly doesn't look like it has any teeth.
see here.... http://67-72chevytrucks.com/vboard/showpost.php?p=4482393&postcount=79
Input welcome!
Shortly after Ford killed off the gear driven VSS, they eliminated the drive gear on the output shaft so there is a very good chance your transmission can't drive a cable.
Worst case is a different output shaft, requires a full trans breakdown. A fresh set of consumables while on there might be a good idea.
