List of Useful Threads - Everything I know about the M5OD-R1 & BW1354M | Page 9 | Ford Explorer Forums
List of Useful Threads Everything I know about the M5OD-R1 & BW1354M
Part Numbers
LMC TRUCK IS SELLING A LOT OF THESE PARTS NOW
Ford
Flywheel Single-Mass for OHV..........................................................................................F77Z-6375-BA $117
Flywheel Dual-Mass for SOHC...........................................................................................? $800+
Clutch Disc for OHV..........................................................................................F87Z-7550-AA $114.09 + $7 core
Clutch Disc for SOHC.....................................................................................................? (see Luk below)
Pressure Plate for OHV.......................................................................................YL5Z-7563-AA $140.18 + $20 core
Pressure Plate for SOHC..................................................................................................? (see Luk below)
Pressure Plate to Flywheel Bolts (at least for OHV) (need 6, washers attached)........................N802096-S2
Slave Cylinder - YL5Z-7A508-AA $86.82 (according to Luk's Tech Bulletin ref Ford bull #06-23-13 revised slave 6L5Z-7A508-AA)
Slave Cylinder to Transmission bolts (need 2).....................................................................N605907-S103 $1.44 each
Steel Plate between Engine & Trans Bellhousing (diff from auto)............................................1L5Z-7007-AA $35.66
Clutch & Brake Pedal Assembly.........................................................................................3L2Z-2455-DA $51.32
Manual Trans Starter (diff from auto)..............................................................F87Z-11002-BARM $162.08 + $75 core
Clutch Master Cylinder (comes with black reservoir).............................................................F87Z-7A543-AA $92.18
Separate Clutch Reservoir (clear plastic)............................................................................lost number
Master Cylinder to Slave Cylinder Plastic Tube....................................................................F87Z-7A512-AA $88.54
Clip (and fastener?) securing Plastic Tube to underneath floor pan...................................just use a zip-tie, Mr. ****!
Clutch Pedal Position (CPP) Switch...................................................................................1L5Z-11A152-AA $38.62
auto or man Ext Housing to elec or man T-Case Bolt (need 5)................................................N605804-S100
auto or man Flywheel/Flexplate to SOHC Crankshaft Bolts (need 8).........................................F77Z-6379-AC
Flywheel to Crankshaft Bolts for OHV (need 6) (I'm unsure if the OHV is different here) ...............E69Z-6379-A
Ext Housing to T-Case Paper Gasket............................................................................E9TZ-7086-A $6
Standard Black Transmission Shifter.....................................................................................F87Z-7210-BA $92.29
FX4 (02+) Transmission Chrome Shifter...............................................................................1L5Z-7210-BC $106.36
(apparently superseded by 6L5Z-7210-BA $300 fx4 shifter ? - Ranger-Forums - The Ultimate Ford Ranger Resource)
FX4 (02+) Transmission Ball for Chrome Shifter.....................................................................1L5Z-7213-AA $85
The shifter pinch nut tends to vibrate off (fell thru onto the road on the highway). I picked up an extra 2nd nut at Home Depot to back onto the primary nut to lock it on.
M5R1 Extension Housing w/ man t-case linkage bosses, w/o OSS sensor hole.............................?
M5R1 Extension Housing w/o bosses, w/ OSS sensor hole.......................................................?
FX4 (02-03) M5R1 Extension Housing w/ bosses, w/ OSS sensor hole (uber rare!).......................1L5Z-7A039-CA ($223.57)
Extension Housing seal for both w/ & w/o OSS......................................................................? (written on seal)
1-piece OSS Sensor (I think it comes with the bolt)..............................................................1L5Z-7H103-AA $23.10
2-piece OSS Sensor with metal retainer...............................................................................unknown
Standard 1-Piece T-Case Shift Linkage................................................................................F0TZ-7210-A ($316)
Standard Black Rubber T-Case Shift Knob.............................................................................unknown
T-Case Shift Linkage Bushing..............................................................................................3L5Z-7335-AA ($7.19)
FX4 (02-03) T-Case Chrome Upper Half Shifter (comes with 2 bolts?).........................................1L5Z-7210-AD ($159) (not confirmed yet)
FX4 (02-03) T-Case Ball for Chrome Shifter............................................................................1L5Z-7213-AB ($108)
FX4 (02-03) T-Case Lower Half Linkage for Chrome Shifter........................................................2M5Z-7210-AB (having a tough time with this one, but this is the best I got so far)
T-Case Shift Linkage Smaller Rear Boss Bolt............................................................................56538-S100 (3/8"-16 x ~1.0")
T-Case Shift Linkage Larger Pivot Forward Boss Bolt (also needs 2 piece plastic washer bushing)......unknown (9/16"-12 x 1.0" with 1.5"x0.75" unthreaded shaft)
Manual Transmission, Electric T-Case Shifter Floor Plate............................................................F87Z-7479-BA $68
Manual Transmission, Electric T-Case Inner Rubber Shift Boot (for both Ex & Ranger)......................1L5Z-7277-AB $22
FX4 Dual Shifter Rubber Inner Shift Boot & Plate.......................................................................2L5Z-7479-AB (not confirmed)
Upper Steering Column Shroud Black (without auto shifter hole, but with key lock button hole).........F57Z-3530-B ($20) (def works for a 98 Ranger & 99 Ex)
Instrument Panel Block (replaces P R D 2 3 letters and blocks light)...............................................F57Z-7B100-A $7.34
BW 13-54M VSS (comes with metal retainer).............................................................................E3AF-9E731-AB
Aftermarket
Luk OHV Clutch Kit...............................................................................................................07-139
Luk SOHC Clutch Kit.............................................................................................................07-167
Luk Slave Cylinder (w/o throwout bearing) (replaced revised 6L5Z-7A508-AA)................................LSC003
Luk Master Cylinder (1999)....................................................................................................LMC346
Luk Master Cylinder (2003)....................................................................................................LMC374 (difference?)
Luk OHV Single-Mass Flywheel...............................................................................................LFW155
CenterForce OHV Dual-Friction Clutch Kit (Luk makes the Pressure Plate & Clutch Disc internals).......?
Centerforce SOHC Dual-Friction Clutch Kit...............................................................................?
AutoZone Duralast Gold Manual Trans Starter (New, Not Rebuilt & Lifetime warranty. highly recommended) ...... DLG3232S $145 +$25 core
3" Shifter Extension for PA Body Lift.......................................................................................PRA-3700 (SE3700)
LMC Truck Reverse Light Switch Socket Connector (splices into auto harness for clean install, but fit is poor)......47-0901 $3.95
Motorcraft Reverse Light Switch Socket Connector ...................................................WPT826
LMC Truck Reverse Light Switch (in case you lose the one that came with the trans).....................47-0862 $14.95
Autel MaxiDiag US703 Diagnostic Scan Tool (HIGHLY RECOMMENDED, only sub $1000 scanner that scans ALL FORD CODES, yes ABS & Airbag codes)...................................................................................................................~$145 on Amazon.com
Steeda 17mm (11/16") Driveshaft Spacer 555-7707 or JEGS 555-60620 (designed for Mustang 8.8 axles - used to make up the 1" difference between the BW4405 & BW1354 t-cases instead of lengthening the driveshaft)
VINs
The dealerships can find parts easier if you give them a VIN. My trick is to search craigslist.com and ebay for a vehicle for sale that has the part you need. I did this a lot for Ranger FX4s with twin chrome sticks. Use the free craigspal.com to search for vehicles for sale across the country. I looked at the interior pictures to confirm that the truck had these shifters. Then contact the seller, pretend to be interested in buying their truck, and ask for the VIN so you can do a background check for major collisions. I've done this successfully to find really uncommon part numbers like the FX4 chrome shifters and the upper steering column shroud.
Did some research on www.fordparts.com:
All 7210's are "Auto Trans Shift Lever"
1L5Z-7210-AB "Genuine" Ranger 4x4, w/ FX4 Off-Road Package; Transfer Case, Lower Control Lever Asy
$354.38 Fits at least: 02 Ranger
1L5Z-7210-AD "Genuine" Ranger 4x4, w/ FX4 Off-Road Package; SHIFT LEVER BEZEL; use together with
the round 2L5Z-7277-AC transmission lever boot and the oval 2L5Z-7277-AD transfer case lever boot
$175.98 Fits at least: 02 Ranger
1L5Z-7210-AE All Diesel - South America only; Gear Shift Lever
$111.47
1L5Z-7210-BB All Diesel - South America only; Lever & Extension Asy.
$200.00
1L5Z-7210-BC Gas Engines, w/ Manual Transfer Case (Genuine Ranger, FX4), Upper Lever & Extension Asy, Manual Transmission; refer to"7003" transmission parts list for Lower -
$292.40
1L5Z-7210-CA Gas Engines, w/ Electric Transfer Case; Upper Lever & Extension Asy, Manual Transmission; refer to "7003" transmission parts list for Lower -
$141.15
2L5Z-7210-AC "Genuine" Ranger 4x4, w/ FX4 Off-Road Package; Transfer Case, Upper Control Lever Asy
$367.07
F8YZ-7210-AA Electric Ranger program; Incl. boot an knob
$56.82
XL2Z-7210-BA Lever assembly - includes 7210, 7213, 7G550, 7A214, 3513 (upper), and 14A163
$46.72
All 7213's are "Auto Trans Shift Lever Knob"
All 7277's are "Auto Trans Shift Lever Boot"
All 7479's are "Auto Trans Gear Shift Blanking Plate"
I know this post was made years ago and no one has probably kept track of it, but by chance does anyone know where I can pick up some of these parts, I'm looking for the flywheel to crank bolts, clutch to flywheel bolts, and slave cylinder bolts for a 4.0 SOHC. If anyone knows a good place to get these or the bolt length and thread pitch that would be amazing. Thank you
College ain’t cheep where do I send the check.
