- December 25, 2023
- Longview, Washington
- 2001 Explorer Sport 4x4
- Callsign
- BLUE
Hey y’all, as many of you know, I drive a 2001 2 door Explorer sport. The truck had some road noise, ride quality and some issues making it so the passenger door shuts improperly. I diagnosed it with bad body mount bushings (some of them I could put my finger through, some others simply weren’t even there anymore). Someone bought me new bushings as a gift so I can fix the issues I had. The problem is, they were sport trac bushings and only properly match up (I’m pretty sure) with positions 1, 2, and 3. By the time I got them, we couldn’t refund them. So I decided to just replace what I had. Now that I’ve replaced them, my passenger door aligns properly and closes like it’s brand new again and road imperfections are far less harsh inside the truck. But, the road noise has gotten a lot worse than it was before. Between like 10-45mph the noise is bearable but it’s at its worst between 50-75mph. Right around 80 and above it quiets up again. When going above 25ish mph and cornering to the left (when some body roll is introduced) the noise disappears entirely. However this does not happen when cornering to the right. This last symptom was the same with the worst of my road noise before replacing the bushings. When I’d be going around 35 and above and the interior was loud, I’d corner to the left and a lot of the noise would go away.
Does anyone know of anything that could be causing this excessive road noise? Has anyone experienced anything like this in the past? I don’t think it’s from the motor or its mounts because the noise doesn’t change with RPM, only with speed. As always, any and all help is appreciated!
