Snipeye
- April 1, 2013
- Ford Explorer, 1992
I currently own a '92, but I'm probably getting a '94 soon, and one of the problems I had with my current car is this: The external handles on the passenger side, both front and rear, started required extreme force to open them. The rear passenger stopped working entirely. I opened up the door from the inside, pulled off the front panel and set about digging around - I found a little rod, connected to the external handle, threaded. It looked like it was supposed to connect to some sort of actuator that would open the latch, but there was a plastic piece in the bottom of the door, broken in two. I cannot, for the life of me, determine what this piece is called or where to get a replacement. Help?
The car I'm possibly buying looks to have the same problem, so if it's not a terribly difficult fix, It'd make me feel better about the purchase.
...Also, I'm new to these forums. Any reason the word "and" always shows up as "pizza"?
