Lakey
- January 10, 2008
- Geelong, Victoria, Australia
- 2002 XLT
Hi everyone. Greetings from Australia.
I have a 2002 Explorer V8 XLT with an ongoing 4x4 problem. For no reason the 4x4 system engages and disengages every few seconds when under load. There is no light action, as would be normal if the system was engaging due to wheel slip.
The 4x4 system otherwise works fine and 4x4 High and Low can be selected manually. Interestingly you can manually fix the problem by selecting 4x4 high, which locks it in 4x4.
I first noticed this when I fitted slightly larger diameter tyres. 75,s rather than the stock 70’s.
Any suggestions????
Any suggestions????
