94Eddie
- September 18, 2003
- 2010 Mountaineer Premier
I suggest using 10w30 or 10w40. You need to use an overall thicker oil and not a wider viscosity range. I use 10w30 and have had no issues so far and valve train noise is very low.The noise appears only at idle, can hear it up to apr. 1000 rpm. Tried today 0w40 oil-the knock is much quieter but still there. As i changed the phaser and the knock did not disappear-I think I may have problems with oil pressure…but in my case at 60 k miles only I don’t want to believed that I need to change the whole timing to get rid of this knock(
