4.6L 3v Camshaft Phaser Knock Noise Fix | Ford Explorer - Ford Ranger Forums - Serious Explorations
makuloco2000
2012 Explorer XLT
In this video I go over in detail the procedure to swap out the Cam Phaser to get rid of that annoying knocking noise at idle! It is easier than you think. The procedure is the same for all 4.6l and 5.4l 3valve engines.
Boomyal
Vancouver, WA
2006 Explorer Ltd
Explorer_PL
Rockland County, NY
06EB V8
Thanks Maculoco
I am chasing a similar noise on my 4.6 with 179 k miles. Part of it is broken stud on exhaust manifold, but I thought I am hearing lifters as well, or that phaser. I need to take the stethoscope and listen which side that is.
sublime54321
Boise, Idaho
2006 V8 Eddie Bauer
This sounds like exactly the noise I've been trying to track down... I'm gonna go broke getting this fixed!
Explorer_PL
Rockland County, NY
06EB V8
Maculoco -
What's the "hour" estimate for this job by Ford's book ?
Eric0508
Michigan
2008 Explorer XLT V8
Hop on over to a Ford truck forum to see how common this is on the 5.4
Usually its caused by a failed tensioner seal which is why i reccomend that if you want to fix the noise, you need to tear the front cover open and replace all the timing components. Unfortunately many people have just replaced the cam-phaser, and the noise reappears 5-10K miles down the road.
Lockouts are becomming a popular option, but you have to run a tune with them and you lose the advangates of the variable timing system.
