wollimann
- July 19, 2011
- Location
- Europe Germany
- Europe (Germany)
- 1997 4.0 sohc xlt
It dosen't matter, pressure is pressure, the gauge needle must move.Couldn't it also be a problem that my pressure gauge doesn't have a vent line?
You simply have no fuel pressure. As i said, no running without pressure.what if the fuel does not appear after pushing it
Every time you hit the ignition the pump runs for 2 seconds and build pressure.
If you do that 2-4 times, there is enough pressure to start the engine.
I bet there is a leak inside the tank (rubber hose/clamp).
