explorer abs codes | Ford Explorer Forums
explorer abs codes
magna19
northeast pa
1994 explorer xlt
how do you get the codes out of a 94 explorer?got abs light on and wish to fix it.
not sure about getting codes but I would take off the wheels and clean and check the connections on all the abs sensors.it could be as simple as a connector coming loose.
the thing that sucks is just the abs light is on,not the brake light.i have the same diagnostic connector as the motor has minus the jumper wire,and there is a green,black,white and black w/white stripe wire on it in the connector.this has 4w abs.had the front right wheel off sunday,no problem with the sensor,end clean.
for a living i work on class 8 trucks,so abs sensors are nothing new to me since the big ones have the basic same system,except have 4 or 6 sensors,and modulator valves.
