Doug904
Sponsor
- March 30, 2001
- Jasper, Alabama
- 2005 Roush GT
Hey guys,
We had a few guys show up and had some great results along with some great learning experiences. The biggest was from using larger TB's, headers, and MAF's but that will come on down the post.
First the constant vehicle to begin from was Aldive's truck, Al, 99' Explorer with a Mac CAI, cat-back exhaust(manufactorer?), and blue Micro Tuner. We had planned on simply using a chip to make changes to and pluging and unplugging it but his port was disabled, like 90% of the Explorer/Ranger crowd. So we had to use a X-calibrator to make the changes each time and that kinda restricted us on how many changes we could make because each time we had to reflash the PCM along with making changes. This would make for about 10 minutes between runs and when you're paying $85 an hour sitting there doesn't make for time well spent.
We started with a stock run....181rwhp and 203 rwtq
Base 99' Exp w/CAI and Exhaust
Next we tried my 89 Performance mail order program...189rwhp and 216rwtq
89 Performance
Next we tried my 93 Performance Mail order program...193rwhp and 217rwtq
Then a few adjustments to the tuning....196rwhp and 218rwtq
93 Performance Tuned...
Now that was it for my programming files so then we started tuning for the Pro-M ( Thanks Monmox-Kevin!). BOY was that a great day! We left my adjusted 93 Peformance program installed so we wouldn't have to reflash the PCM. The first run with the Pro-M SUCKED!! The A/F went so lean that the dyno guy shut down the run...
Pro-M base line shut down
Next I went in and made some adjustments to help get it down to a safe range and also correct the idle as it was staying in Open loop even at idle because the transfer function was so far off, that's why the CEL would come on for you guys with the Pro-M's.
Pro-M adjusted 1st run 193rwhp and 217 rwtq
Since I had gotten the a/f down to a safe range I leaned it out a bit and did our final run...197rwhp and 220 rwtq...
Pro-M Final run....
With all the tuning and such we were only able to make 1rwhp increase and 3rwtq. There again that could be the difference between two runs ran back to back so for $200-$300 everyone is paying for these your not making your money back and if your vehicle is staying in Open loop like the this one your killing your fuel milage and probably running very rich at idle destroying your 02's and lean up top burning up your spark plugs or even worse. Ive also got a comparison to a C&L meter but that comes on down the post...
So, now we got everything close as can be we decided to return the vehicle to the 89 performance file, and see what changes the 73 C&L meter was making. To our great surprise it ran a PERFECT 13:1 a/f ratio and even made 8-10 rwhp more with the 89 performance program! It was making the same performance numbers using 89 that we were seeing using the 93 tuning.
First C&L run....
I know I know, kick me in the tail but we didn't run it using the 93 Performance program. We were at nearly 3 hours on the dyno and the money aspect was starting to cloud my other thinking.
I did make a run using the C&L and the TORNADO!!! We didn't make sqaut!
Tornado using C&L
Here are the last two runs over each other...
C&L Vs. C&L w/Tornado..
Finally, here are two runs using the 93 Performance program with the Pro-M tuned program and using the 89 Performance program using the C&L meter..
C&L 89 perf VS. Pro-M 93 perf. and tuned...
Now, that was with Aldive's Explorer. We had a second Explorer show up as well, a 98 SOHC Sport w/ auto. He is in prepairing to install a STS turbo on his Explorer but wanted some baseline numbers with what he has now. His mod list includes...
JBA headers, 76mm C&L, 70mm TB, and 3" exhaust. Sounds like it should do very well huh?
With his first run we had to do some major tuning work. Luckily his PCM's port wasn't disabled so we were able to use the chip for doing the programming on and not have to reprogram the PCM each time.
I'm not going into detail as much as we did with Al's but here is his run with the 76mm MAF...
76mm C&L tuned....
Next, we wanted to see whta affect the 73mm C&L would have on his HP and also the base programming. Funny thing, we got the same amount of power from his Explorer with the 73 then we did with the 76...
73mm C&L...
Now don't go by the torque number at the top of that run, on a automatic truck sometimes the converter will slip or flash on quick stabs of the throttle like on a dyno and cause a spike in the numbers. The next graph I show with the two comparisons will show that they are very close on the 73 and 76 on the torque numbers...
73 C&L vs 76 C&L
In short this shows that using all of these high flowing components will not aid in the performance of a n/a vehicle. Al actually made more HP then him with stock manifolds and a smaller exhaust system. Is this bad? No, it will work alot better when he has his turbo installed but for now it's a bit low. This also shows the difference between vehicles for one to another.
All in all I had a great time and I met alot of great people. AL took alot of photo's but won't be back in Florida for a few days so I'm sure he'll post a few when he gets home. I was running from truck to truck so that I didn't get a chance to do this, I was too busy swapping MAF's and reprogramming PCM's to do much of anything else. When I got home I went to bed and just have gotten up this morning.
I will be offering the C&L meters very soon as well so I'll keep everyone posted when I do. I've been working with them for a little bit now and said that I wasnt going to sell anything until I could find out how they did and most of all what kind of increases they gave. I will have them listed on my NEW website very soon...
Thanks! Doug.
89 Performance
Pro-M Final run....
First C&L run....
Tornado using C&L
76mm C&L tuned....
73mm C&L...
73 C&L vs 76 C&L
Thanks! Doug.
