EXPLORER PRO COMP LIFT 3"95-2001 2wd | Ford Explorer Forums - Serious Explorations
SCEXPLORER
Los Angeles, CA
1997 Explorer Sport
OK NOW! What is going on? I was just browsing in the explorer pro comps website and saw that they make
a 3" spindle suspension lift for 2wd. 95-2001 explorers. So is this true? What about the welded torsoin mounts? If the torsion bar mounts is the only problem than it is possible to do this lift right!?? I also have a 1997 explorer sport monleaf so would that still work? What steps would i need to take to make this kit work. It costs about $500 at 4wheelparts. Please give me your input.
Yes this will work the spindles along are 500 bucks. if you use the rear kit from the super lift or trail master kit that will take care of the rear. 3 inches from spindles + 1 from cranking up the torsion bars gives you 4 inches for the rear.
