- February 25, 2011
- Moderator
- 2020 Explorer ST
Guys, towing weights are generally limited by suspension/braking capability. Takes a whole lot more to stop something quickly than it does to get it rolling.
For what it's worth, the Touareg with the 3.0L diesel was one of the best towing rigs for medium to light loads of any vehicle I've ever had. It was also really fun to drive with excellent performance and handling. Then VW "fixed" it's EPA diesel problem and turned a $64,000 car into a piece of sh*t.
That's how I got the Explorer I have now.
Brakes are important but I disagree to an extent. When you are towing 5,000lbs that trailer will have its own brakes. Those brakes are supposed to be sufficient enough to stop the trailer and not rely on the tow vehicle. I have a 40ft 5th wheel that is almost 14,000lbs and when I brake with my truck, I don't feel the trailer.. nor do I feel that the trailer is ever trying to push me. Trailer brakes needs to be setup properly with the proper settings and regardless of tow vehicle, if setup right, you should not be white knuckled when trying to stop.. it should be smooth and effortless.
Now if we are talking a trailer that doesn't have its own brakes (which would be significantly less weight), that's a different story.
