Explorer weight? | Ford Explorer Forums
Explorer weight?
johnh
San Diego, ca
!998 four door
I am considering purchasing an explorer and can not seem to get reliable info from anyone regarding the actual weight of an explorer. I need to know the weight of a base model 1998 to 2003 explorer sport 2 door both in 2 and 4 wheel drive. Does any of you really know the true total weight of these two models?
I also need to know the comparable weight of the production years from 1998-2004 in a four door version both 2 and 4 wheel drive..
My last question is what is the wheel base of a 2 versus 4 door model?
Thank you for your help.
Weight varies from ~ 3800-4400 depending on model and equipment.
Approx 102" and 112" for WB.
explorer weight
I am not looking for approximations I am looking for actual weight. Do any of you really know hat exactly is the weight difference between a 2 and 4 door? What exactly is the wheelbase of a 2 door versus a 4 door?(Assume each is exactly the same year, model and equipment)
1998 2-Door Explorers
2WD - 101.7" - 3,692 lbs.
4WD - 101.7" - 3,919 lbs.
1998 4-Door Explorers
2WD - 111.6" - 3,911 lbs.
4WD - 111.6" - 4,146 lbs.
AWD - 111.6" - 4,166 lbs.
Edit: All of the above info was obtained at Edmunds.com
Edit #2: The lengths are wheelbase and weights are curb weight.
