air shock raise and lower
The suspension system is load leveling, all you have to do is trick into thinking it has a heavy load and it will raise its self. For the front, your sensor (looks like a little plastic shock) is on the drivers side, (turn your wheel to the right to see it) Make sure your air ride system is turned on (switch is at the back in the jack compartment). Unclip the bottom of the shock, and compress it with your hands, the front will lift right away. When you have it at the desired hight, run back to the switch and shut it off. do the same to the sensor at the back and presto! free lift. to slam it do the opposite, decompress the shock sensor. To keep it at the hight you want, you must have the system switch off. The minute you turn the switch on you will go back to regular riding hight. Oh! make sure you clip the sensor shock back, you may lose it if you don't. Any questions? have fun.
Dustin
