EvinH
- August 9, 2013
- Catskill, NY
- 2001 Ford Explorer ST
Hopefully someone can help point me in the right direction as to what I may need to do to fix this issue on my 01 ST. For a while now, when stopping from low speed, like in traffic or coming up on a stop sign/traffic light, I'm getting feedback in the brake pedal as if the ABS is kicking in. Initially I thought it was cause my brakes were bad. I have recently put new rotors and pads on. I topped off the fluid and will be bleeding the brakes tomorrow. I also changed the rear shoes about 4-5 months ago. Anyone have any idea what could be causing this? Bad ABS sensor? I've noticed that either the bulb for the ABS light in the dash is out or it's not working correctly as it does not light when this issue happens and it doesn't light up when I've stopped hard in the snow lately to see if the light comes on.
