Blackout51
- August 31, 2014
- St. Louis, MO
- 1998 explorer sport
I have a 1998 explorer sport 4.0 sohc 4wd, I just did a minor upper engine refresh (changed out leaking valve cover gasket, upper intake manifold gaskets, cleaned butterfly valve in upper intake manifold, cleaned throttle body, new thermostat and housing, new water pump). Now I have two CEL codes and theres a weird noise coming from behind the passenger air bag, first of all the CELs are one for the air pump thing that sits on top of the intake manifold that helps control the idle, so when I have it in park idling it idles around 1400 rpm, the sensor/pump is new and clean so I don't know what could be the issue there, would adjusting the idle screw help? the second CEL is an emissions code that I did some digging and found the others got this code when there was a leak in the fuel system somewhere, I did notice when I filled the explorer up last time when it was about to click off some fuel shot out underneath between the tank and the filler hole, could this be a cracked fuel filler pipe? it was definitely up in the metal part where the fuel shot out not the lower rubber part. Now the noise isn't so much a problem as a slight annoyance, every time I start the explorer up theres this clicking/tapping noise under the passengers dash that goes away after a few seconds, it sounds kind of like a bad bearing on the blower motor but the fan isn't on when it happens and when I turn the fan on theres no noise. Sorry for the essay here but any ideas/thoughts on these are appreciated!
