anth2c
- August 22, 2009
- letcher, ky
- 1999 explorer 4.0 ohv
ive got a couple questions....ive got a 99 explorer 4.0 ohv
i think recently ive gotten some water in the gas i dont know how much but it started running horrbile. ive put additive in to help with it. well it has gotten better but occasionly it will still die on me while driving(usually going downhill or coming to a stop). but i can put it in N and it wil start right back up. now if im going say 55 or 60 and i mash the gas it start hesitating somewhat and wont kick into overdrive. ive been having transmission problems too i dont know if this hesitation is cause by the transmission or the actual motor itself needing something. when the engine was running its worst it was fine on level ground but if you started going uphill it was horrible it wouldnt go over 30 mph.
ok next question. if im going say 60 and let off the gas the rpms drop from around 3000(should it be at this rpm range at 60?) to idle and when u get back on the gas it wont start pulling until it gets back up to around 2500(not normal is it?). is this cause by the trasnmission problem ive been having? the problems i have are late shifting from 1st to second at around 4500 unless i easily pull out. then when it shifts again it shifts quickly . and most of the time the first shift is hard.
