Well, after talking with James last week up in Jasper, I decided to look through the catalogs at work. I ordered a few different fuel pressure tester kits, and found one that I thought would work. Low and behold, it's the same thread as my fuel rail
I removed the schrader valve from the adapter and I was wondering if I could/should drill it out more, since I was a little worried about getting fuel (I also though of the fact that the actual fuel nozzle pill is much smaller than this hole, but I've had enough engineering classes to know that the shape of the nozzle and all comes into play on the exit velocity and mass flow rate). If I drill out the hole to be the same width the whole way through, will I mess with the part's strength/integrity or fuel flow? I figure at 60psi, it won't make that much difference, but I want to be sure. I took a pic from the top to show the width of the hole that's there and you can see I can go appx a milimeter on either side to add 2mm of diameter to the adapter. Will this be okay?
I'm excited, I had all but given up hope on finding this part and was looking for good spots to tap the fuel rail, now I won't have to
Adapter (I don't know what thread the female is but it fits, to 4AN
From the top, see the restriction
