1995E
- July 16, 2010
- Maryland
- 95 + 11 Ex both XLT
Okay, I installed my 55W Chinese made digital slim ballasts and 6000K HIDs on both headlights. These things are waayyyy too bright. Hopefully they will dim down with age because I did not expect it to light up the front of the road like a stadium light would.
However, I have a problem. I noticed that when going down the highway, my HID bulbs flicker a lot, like the lights stay on but the bright spots are dimming then brightening, noticeably only on one side. The kits didn't come with an HID relay wiring harness to wire to the battery and I am wonder if that is why they are flickering, or... is the ballast bad?
I plan to install an HID relay wiring harness on these. I also plan to add a delay. However, I don't want to buy the delay relay I find online because it's like 15 bucks. I am planning to make my own delay somehow. I looked online and found that if I add a capacitor between the relay and the stock wiring, it will also add a delay, and depending on the capacitor, I can customize however long the delay will be. Is this correct or do I need to add something else?
Edit: Also, I mounted my ballasts where there are existing screws like the air intake and the radiator mount. Is that safe or is that a totally bad idea? Also, would adding a heatsink do anything for the ballasts? I am planning to add a CPU heatsink to the ballast to help it cool down but it seems unnecessary. I am just worried cause they get pretty hot.
EDIT: I wasn't sure if posting this on the HID install thread that already existed was appropriate or not so if a moderator wants to merge this thread, please do so.
