Flowmaster Delta Install | Ford Explorer Forums
Lazzman
Massachusetts
1998 Sport 4wd- V6 Sohc
Installed the Flowmaster 50 series muffler on my '98 Sport yesterday. Used 2.5" tubing and a single exhaust finishing in a chromed 3" angle cut tip.
It looks really bad ass but I was hoping for a bit more of a performance upgrade. It is definately a lot louder than the stock muffler and resonates a bit loud in 2-3rd gear around 3000+ rpm. It does quite down though to a nice drone at cruising speeds.
This muffler was dealer suggested to me as being relatively quite compared to the other flowmasters and it is more than twice as loud as stock- so those thinking of an upgrade do your research, if I had it to do over again I probably would have used the 70 series.
My drawback was that I did not experience the added power I thought I would. I thought the muffler system would really let the Volant intake do its thing and it hasn't. I noticed a much better performance gain from the intake kit. They both cost about the same to install around $250.
The overall throttle response is much better and the truck leaps off the line with the 4.10 Dif but mid and high end seems the same. Also I think the added power has messed up the failing valve body in my 5R55E tranny.
well if you didnt get what you wanted, consider tuning it with a tuner from Bamachips to teach your truck how to use the intake and exhaust to its full potential. I bet you will be happy then!
So True Afboy, I just have to save up the $300 some odd duckets to do so.
try letting the computer reset( disconnect the battery for 30min or so) and see if that helps.
well lets see some pics of it
Ok I will try disconecting the battery. Sorry I do not have the privalage to post pics.
just use a site like image shack or car domain to post pics by posting them and when you hit the reply putton go to the advanced and then hit the image button and copy the image location into the box
Or just become elite!
Sheesh. :rolleyes:
