Flywheel | Ford Explorer Forums
Flywheel
Vanquish502
Kitchener, Ontario
91EB, 91EB, 92XLT
is there any possible way to reinforce a flywheel? I have a 91 and I've already blown apart the center of the flywheel like many others. i was wondering if it would be possible to weld a steel plate in there, drill the holes out again and get longer bolts?
http://www.alldatadiy.com/alldata/A.../56351048/34853741/34850750/42063452/93057214
Also, when you break the flywheel apart, has anyone ever had any of the bolts break? I don't really wanna replace a crankshaft.
Also I bought a flywheel from a 94' Explorer to replace my current one.
I sure hope no one tells me to go to the dealership and buy one of the newer, updated, stronger ones...they aren't $40 here. $230+tax...
dont weld anything to a flywheel ! they are balanced and adding material will throw them off and they can blow apart. I would just go to a local transmission shop and see if you can get a heavy duty flywheel.
You could try having it cryogenicly treated.
Cyrogenically treating it will make it stronger but I've never heard of anyone blowing apart a fly wheel. What are you doing to bust flywheels??
I've done it, and I don't even beat on my $hit. The 91-96 maybe 97 have 6 bolt flywheel and the later models have the 8 bolt.
I could live with a vibration...its not like im gonna make the plate totally of center or anything
