Fog Lamps or Switch | Ford Explorer Forums
Fog Lamps or Switch
fuzzie
Central PA
97 XLT 4D 4WD
My fog lamps just suddenly stopped working. I checked the fuse. It is good.
The light on the switch does not come on when pressed (neither does my rear defroster's light, but that seems to still work).
Both the bulbs couldn't have blown at the same time, could they?
I tried searching to see if this switch is hard to replace or a known problem, without any success.
Is something else going on? Or should I just get new bulbs and see if that fixes the problem?
dont start throwing $$$ at it.
Check for power at the fuse when you flip the switch.
Also if they are aftermarket look around for a relay. Also check the ground wire to the lights.....
Thanks.
They are stock. I'll check the power tonight.
Any idea where the ground is?
