Fog Light trouble help | Ford Explorer Forums
97Qball
Kelowna
97 Limited
:exporange 97 LTD 5.0 I have just replaced both burned out bulbs on my fog lights to find they do not work. Would it be the relay? Where is the relay and how can I ID it from others? Thanks!
Welcome to the site! The relay may be the problem or it could be a fuse or a short circuit. You'll have to check your owners manual to see which relay is the fog light relay and which fuse you need to check. The relays are in a black box mounted on the driver's side fenderwell (IIRC). The fuse is under the dash in the fusebox on the driver's side.
P.S. thread has been moved to the proper forum.
