hakmazter
- February 14, 2001
- Urbandale, IA
- 99 Limited
I am assuming no one knows the answer to this question, but I will give it a try. The Ford Explorer Limited comes with a Mach system that is similar to the Mach460 system in Mustangs. The problem is that when you turn up the volume, the bass decreases. It doesn't matter if you change amps or subs or whatever because it is a function in the deck. Anyone know how to bypass it?
