I'm sure that will be fine, I would have done the exact same thing. I love Ultra Black RTV, I've used it for the normal things, plus a few household needs instead of the cheap caulk products for things like my Chimney, shower drain top seam etc. It doesn't let go in any weather, and last month Amazon has had it for under $5, the Ultra Copper too.
Don, thanks for the conformation.... Just could not see it sealing and I knew those tabs were not going to seat correctly.... Oh yes Ultra Blake is great stuff. I dont remember if I said this or not but in reference to the ultra copper, my wife's sister's daughter's husband... (LOL follow that?). is a farmer, and uses propane tractors. He says they use that on the manifolds and it holds up great. He said they get hot, like cherry red hot.... I found that hard to believe, but I did not argue with him (He is a big man, 6'5", all muscle, was a marine and well, I am smarter than that!) . I have yet to use it, but will.
Alright, drum roll please... I GOT THE TRUCK DONE!!!...
It was a struggle, and a very long day.... along the way I found another rodent chewed set of wires, one of the connectors of the thermostat housing sensors, the grey one... I cut it , put on some shrink tube, soldered it and shrunk the tube on it and called it good... also I replaced the thermostat housing unit...but had one hell of a time getting the top radiator hose on... the top hose connector, at the thermostat on the housing was very tight to the bottom of the throttle body... WTF... so I filed down the TB and it went on ok,... Pulled the fuel pump fuse, cranked it several times for good oil priming, and then put the fuse back, it started right up! Sounds GREAT.... No leaks.... all seems to be right with the world....
I did notice one thing... and I am going to ck it again tomorrow, it my needed to be burped.. I am just not sure about this motor... the temp gauge reads middle of the scale, and I dont think it should have been yet as nothing was hot, it was only a few minutes at after start up, and I was still cking the coolant level, waiting for the thermostat to open... So are these hard to get all the air out, aka burp?
I am really surprised at how well it runs... quieter too... I think the front chain was making some noise but its better now.... And I think I was wrong when I quoted the miles.. it is at about 198k not 225k... not that it makes a great deal of difference... Inside looked good, top and bottom, no sludge any place I saw... could go another 50k easy...
Which one of those sensors on the thermostat housing is the one for the temp? If it is not reading correctly, what should I do? Why would it read in the middle if it was A) not connected, as if my wire repair was not good, and B) could the new sensor be bad?, of C) system has air in it?
Thanks for the great help and input! What a great place! You all were very helpful! I see these for sale and they are pretty cheap, I might even consider one..
Ill report back on what I find on the temp gauge.
Greg
