Found the best way to remove front shocks | Ford Explorer Forums
tojan19
Smithfield VA
06 EB
I'm sure anyone who has changed front shocks knows how much of a PITA it is to remove that top nut. This is the second time I've replaced my front shocks. First time around 70k and now at 140k. Last time I fought with those top bolts for quite a while. This time I was changing out the hubs and CV joints so it was a good time to swap and it needed done anyway. There was no loosening the bolts. Rusted fast. I got fustrated and decided the best option was to simple cut them off. I had the UCA disconnected from the spindle so I had even better access.
So get a good metal cutting blade for a reciprocating saw like a Lenox rescue blade, 6". I cut right above the top of the shock at the base of the stud. Took about 45-60 seconds each side. Easy as pie.
Sorry no pics.
Those bolts are easy to get to from above with about a foot of extension, just hit it with the impact and they come right off.
You forget my shock install? +1 for the saws-all:D
I used a couple of extensions and it was no biggie. :dunno:
Now if you could come up with a killer solution to get some of those pesky rear top bolts off (other than blow a hole in your truck with a shotgun) you'd be the man! :D
Sorry no pics.
Been doing it like that for years; works great.
I'm going to to the rears soon too. I'll get back to you on the size of shot required to blast an appropriate sized hole.
There's always thermite:eek:
