Frame bushings | Ford Explorer Forums
Frame bushings
Tonytitan
NASHVILLE
2001 Explorer Sport
Wanting to replace the body/frame bushings on a 2001 Ex Sport. The least expensive kit for five sets is $170. I can find kits for the Ex Sport Trac for under $100 but the word is that they will not install in a Sport. Is this valid and am I stuck with the big expense? Inquiring minds want to know. Or not.
The Sport Trac bushings use some that are different. I don't recall how many, but at least half are the same.
I don't know what is available now individually, but you might be able to buy the unique bushings for your truck and use a Sport Trac kit if you like those better. Be sure the bushings are the same type though, don't mix soft rubber ones with stiff urethane at different positions.
Sport track is missing some(only 8) as there are none for the bed area. You will need a sport kit that has 10.
