From Russia with Love. | Ford Explorer Forums
Alex3013
Moscow
1993 XL
Hi friends. Help the council. Where did this spring?:crazy:
It is used as a way to stop metal pieces from moving around in the transmission. That is to say a filter.
Thank you friends! You helped me a lot!
Hi friends. I need advice.
What to do with the pump? Why do such damage? Do I need to change the pump on the new one?
The pump requires a special alignment tool. The transmission section has a sticky thread called the A4LD rebuild diary. It takes each part of the rebuild precess step by step. There is another thread on the valve body.
I can not find online information on replacement rear sprag. How to replace?
What to do with the apertures after replacing washers?
