front axle seals different sizes? | Ford Explorer Forums
davejal1991
Rhode Island
'01 Mountaineer
I bought what i believe to be the two front axle seals for where the solid axle meets the cv axle on the right and left side and the two seals are different sizes. Is this correct?
yes, the seals are different sizes.
the driver's side is larger, iirc.
thnx jus making sure so I dont end up having to drop the axle twice and buy more fluid also.
Here's the Timken part #'s if you want to verify :)
Driver's Side Front Axle Shaft:
  • Seal (Viton) - Timken 710429 (OEM Spicer 46065)
  • Bearing - Timken 5707 (OEM Spicer 566121)
Passenger's Side Front Axle Shaft:
  • Seal (Viton) - Timken 710428 (OEM Spicer 46066)
  • Bearing - Timken/Torrington B-268 (S268) (OEM Spicer 566063)
Front Axle Output Shaft Seal (oil slinger between axle shaft and hub assy) - Motorcraft BRS31 (these don't fit on mine?!)
