jlsparky7
- April 4, 2009
- Woodhaven, Mi
- 1996 5.0 XLT AWD
1996 EX XLT 4 door AWD 5.0
Was crawling around under the truck and had a couple questions about changing the front differential fluid.
Can you take the front diff cover off without moving the differential or the front crossmember? Seems like a very tight fit. I would just use a pump and pump the old fluid out and refill it but it looks like the seal is leaking and I need a new cover. Its pretty rusty.
Whats the easiest way to go about changing the front diff cover?
