front end lean | Ford Explorer Forums
front end lean
Ronin8002
Virginia
2008 XLT Ironman
Anybody ever notice that the front driver's side sits slightly lower than the front passenger side? I measured from the ground at the center of the wheel to the bottom edge of the highest part of the fenderwell and I get a 1/2" or so difference. Wonder if this is just something that you see on the 4x4 and AWD models with the front diff and driveshaft being on that side and weighing it down. It's not the springs sagging, I just installed a new set on my coilovers and saw it on the last set I ran too, as well as the stock struts.
Every vehicle that I have ever owned starts to sag (settle) on that side over time because that is the side that gets all the constant in/out use and always has additional passenger weight on it. I fixed that issue on my 96 F150 when I replaced the coils so adding spring preload to that side will do the job.
