jeharman
- November 16, 2009
- 1998 eddie bauer
I have a 1998 eddie bauer. I had a new transfer case put in about 40,000 miles ago. Recently it started making a popping noise the moment you started going forward. I had 3 different mechanics look at it. The first one said it was a upper control arm and ball joint on the right side front as this is where the noise comes from. Thesecond one said it was the left upper control arm and ball joint. The third one finally put it on a lift and it makes no noise in drive or reverse then. He said it was because the tires were too worn down, and told me to put all new tires all around. This did not good still, and the tires are exactly what is called for. This is an automatic all wheel drive. I googled the problem and one google said it was a front vc axel. The last mechanic said the drive train was binding and that was the problem and put new tires on. Has anyone else had this problem
