ian1739
- May 25, 2008
- Ontario, Canada
- '98 Limited 4x4
98 Limited 4x4 4L.
When I got this Explorer, the front air ride shocks had been replaced with gas, no coil overs, just the shocks. Recently I replaced the rear air shocks with gas also, scrapping the compressor and that mess. I plan on putting another leaf or two in the rear or maybe 1250lbs springs from a wrecker, as opposed to the 850s I have in there now. Its not a big issue in the rear, seems to handle weight fine. But I was taking a look at the front end today and noticed less than an inch of clearance between the lower suspension arm and the rubber limiter. Uh oh... thought there should have been a bit more clearance than that. Almost looks like if I put in a new rubber limiter on, it would be bottomed out just sitting there!
Upon further inspection I find that one torsion bar adjusting bolt is cranked in all the way, and the other side is out all the way! wtf?! So I cranked the one side up to match the other, hoping to get a bit more ride height in the front, which helped a bit. But I still don't think the front end is sitting right, seems way to low. Tried to snap a couple pictures:
Pretty bad eh?
So my question: Is there any front end suspension difference between an explorer with air ride, and one without? Stiffer torsion bars, or coil over shocks, or something I can get from the wrecker nice and cheap?
I've been looking online, and can get a 3" lift kit that basically just has new torsion bar adjusters, that I guess loads the torsion bar up enough to raise the vehicle. I know this would be a pretty stiff ride and is a bad way of doing things, but if it will work without putting coilovers on it might be my best bet. I'm not trying to build and off roader, and don't need a $2000 lift kit, but I'm just trying keep the explorer from destroying itself in day to day use.
Any advice here (besides put the air ride back in
) would be great, thanks.
Pretty bad eh?
