Nitrous SSC
- October 17, 2002
- Layton, UT
- 98 Eddie 3-oh-2
Nope its an AWD system thats always engauged.
Bronco638 said:How about swapping in a vacuum assist front axle (1995-96) so you can 'disengage' the right front CV shaft at will? Then, you'd have 3WD instead of AWD and the right front would free wheel.
The vacuum disconnect works fine w/o a locker, but won't work like you're thinking once you put a lunchbox style locker in. With spider gears in, even if the diff is given power the disconnected shaft is allowed to spin either way to 'release' the power. However, with a locker in, the drivers side tire would always be locked in, and so you'd have serious handling issues.Bronco638 said:Nitrous - it shouldn't because there is a disconnect coupling within the axle tube that keeps the short outer axle shaft from turning the CV shaft. The vacuum assist actuates a 'shift fork', very similar to a manual transmission, that moves the coupling which engages or disengages the outer axle shaft (and therefore the CV shaft). The inner axle shaft turns constantly since it slips into the side gears (or NoSlip or LockRite) within the carrier. I have a disassembled front diff at home if you want to see pictures.
