Craigerz
- December 4, 2016
- Fort Worth, TX
- 1997 5.0 4x4
Ill post the question first in case you don't feel like reading and just know the answer. With the Lock Right front locker do the c clips on the front CV shafts stay on or do they come off before installing.
So I have the Lock Right locker up front. It does its job when needed but isn't the friendliest thing to drive. I have had it in for almost a year and a half (?) Its not a daily driver and the only highway use it sees is going from place to place. It was like trying to relearn to drive again with it installed because of the way it works.
Long story short I broke a CV up front the other weekend. Completely my fault, should have taken it out of 4x4 turning that sharp and pop. Limped it to the pavement and got towed home. Crappy day but survivable. Learned a few really valuable lessons that day and thankful I was only 8 miles from my parents place.
Replaced maybe a dozen front CVs (not only in this) and have had my fronts out maybe half dozen times. Once I nicked the front boot with the sawsall cutting off the rusted end links...... But this is the first one I've actually physically broken in half.
When I installed the locker up front I started carrying 2 spare CVs with me, which that day happened to be in my garage. Well that day came. But at the end of the day, for the life of me I could not get the drivers side axle out. I have always been able to pretty much pop them out by hand or with a big flat head. I tried pry bars and beating and tapping and wood and metal and and rotating and cursing.
3 days later I finally got the tool for the end of my slide hammer AND the axle popper tools (look like big forked ball joint separator). Using both at the same time (as skilled as I am there were 2 of us) got it to pop out after about 30 seconds.
I read on here about the drivers side being hard sometimes but this was ridiculous. Got my replacement ( and then the one I broke replacement under warranty ) and cant get either one of them back in. They are both remans but what are the chances of 2 at once? The splines came out undamaged and the c clip wasn't bent or anything odd looking like it was caught. And I've had them out before with just my hands popping them out too. So was this just a case of stubborn not wanting to work right cheap reman CVs? Thought Id ask before trying to force them in as it always just slipped in before.
And I have the instructions, but they are basically generic one set of instructions for every locker they sell type.
