Front Strut Bearings (2) Replaced
Napalm
Memphis tn
Well there went that theory.
There are cases of premature failure on parts, statistical calculations etc. it does happen and it can happen with just about everything made.
sucks though.
without looking at your car - and not knowing how you bought it etc - I almost want to say perhaps the dealer did something to the car before you bought it. Drove into a curb etc. Not saying it happened but it sure makes me wonder. If all is being covered under warranty I wouldn't worry but it does make one scratch the head.
daves temen
Ohio
2012 ford explorer
So, after about 113,000 miles, I needed this repair done.
For several months, had a nagging rattle in the front suspension, and the trucks ride quality had really depreciated. Plus, a noise, groan, and low pitch ping in the steering column when doing low speed turns, or sitting still and rocking the steering wheel back & forth. ABout 113,000 miles.
$456.20
Part & Labor:
Bracket SPO BB5Z 18183 A was $54.10 (need 2) for a $108.20 total
Labor units 3 for $348.00
Noise is now gone. Ride quality now back to normal. Very happy, but wished this failed under warranty.
Stabilizer End Links still need to be replaced. But this is a less $$$ repair.
I am having the same problem. Poorly made and Ford basically wants me to pay it all. Complained to the dealer and no response. Sad Ford Motor Company !
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
I'm see that you are likely out of warranty and guess you didn't get the ESP warranty. Not sure why Ford should cover a suspension part that is no longer under warranty. They have to draw the line some where. That is one reason they offer extended warranties. Depending on how far out warranty a vehicle is, some dealers do perform 'good will' repairs for a lesser cost but that would be up to the individual dealership.
Patrick Capel
2011 Ford Explorer XLT
I am experiencing this issue as well, at 113K miles. I can see the top of the strut (from below) hang up and then go "TWANG" when turning the wheel, so it sounds like the mount needs to be replaced. I actually did buy the ExtraCare when I bought the vehicle a year ago, so I am still under that. However, I've been informed that even though ExtraCare coverage states "MacPherson struts", that it does not cover the strut mounts. Not the answer I wanted to hear, so now I need figure out if I want to take it to Ford to fix, or try to do it myself.
Napalm
Memphis tn
I'm surprised they cover the struts honestly. if they are going to cover the struts they probably will cover themounts and bearings. good luck with it either way though.
CommandPresence
Massachusetts
2018 Explorer XLT 3.5L NA
Interesting I found this post. My 14' is making the same noise!!! I'm livid, only 59k easy miles and it knocks and clunks over every little bump from pulling into a driveway to a small crack in the road at low speeds. Dealer says no coverage. 36k mile coverage and that's that. NOT HAPPY.
Napalm
Memphis tn
is this on your interceptor utility or on your personal car. How old and did you get the extended warranty on it.
If on the police utility then I suspect that warranty is very different and might not last that long. If on the personal car and you don't have the extended warranty then the dealer is somewhat correct. IF your warranty time and miles has elapsed.
However is there any sort of service letter or bulletin on the front suspension noise/strut bearing wear?
OH and do you have any modifications to the car?
peterk9
Staff member
Moderator
Callsign
VE3
Has it been diagnosed as the bearings? There is this as well; http://www.explorerforum.com/xenforo/index.php?threads/2011-explorer-tsbs-ssms.343204/#post-3511715
CommandPresence
Massachusetts
I will be going to a local dealer to try and sort this out. Hopefully I can get this resolved, thanks for the replies! peterk9 always coming in handy!
PDExplorer
Long Island, NY
16 Xsport, 12 Mustang GT
Does ford service still monitor the forums? I'm having this issue, brought it to the dealer and they said the clunking in hearing is normal. Makes no sense to me. Sounds to me like pushing it off until it's out of warranty. Only 17000 miles on it. Also did the TSB on my heated and cooled seats which didn't fix a thing. Joy
Sixonemale
2015 XLT Appearance Pkg
In general clunking noises coming from the front end suspension are not normal, but a common problem with this generation of Explorer. If the clunking noise is easy to generate I would take it to another dealership or two in effort to get a second or third opinion, and/or if other dealerships are not close by, take to a reputable independent repair shop to get their feedback. There are several threads that talk about this topic that you may want to read.
peterk9
Staff member
Moderator
Callsign
VE3
Yes they do but they also monitor other sites so I recommend sending them a PM to ensure they are aware of your concern.
t4rest
Mabank, TX
2011 Ltd
I know this thread my be old but I'm having the same noise/problem with the front strut mounts. WARDSTER, wrote that he replaced the existing one with the Police Interceptor versions on is '13 XLT. (DG1Z-18183-B). The question I have is will that work on 2011 Limited? The original part number for the 2011 is (BB5Z-18183-A). If that doesn't work what about replacing everything, Strut,Spring and Mount
peterk9
Staff member
Moderator
Callsign
VE3
Why not use the original part number? They are both listed at $54.57.
t4rest
Mabank, TX
2011 Ltd
I am making an assumption that the PIU version is stronger because the server duty that a police vehicle goes through. If not why would they change the part if the original part would do the job.
CommandPresence
Massachusetts
I'd like to chime in, my clunk was lower control arm bushings that were completely deteriorated. Needs to be replaced as entire arm/assembly.
peterk9
Staff member
Moderator
Callsign
VE3
The complete PIU suspension is different and tuned differently. Therefore you would probably have to change several parts which would be much more expensive than just replacing the current part(s).
Stracken23
Macomb MI
2013 Ford Explorer XLT
So I changed both mounts. Some notes if you are interested. The factory mounts use plastic bushings, just basically two flat pieces greased up. The Motorcraft replacement mounts use steel ball bearings. However they are not sealed bearings and the two haves come apart rather easily. I found myself picking up several of the balls with my magnet and re-greasing them with bearing grease (I hope I found them all).
Notes on the job. #1 the springs are really long when uncompressed, make sure your strut machine is set to allow a few inches of travel beyond the top of the assembled strut. #2 try to get the strut as level as possible if using a strut machine and put it in with the hub attachment points facing away from you. The strut tends to tilt inside the spring without the upper mount in place due to the angle at which the spring sits in the strut and it is easier to push the lower part of the strut than pull it while trying to install the mount. #3 support the lower control arm and brake assembly with a jack. If it sags too far things loosen up and it will be hard to put them all back in place.
It took me 5 hours to do the first side while learning those three lessons. It only took 2 hours to do the other side, would have been less if not for the little bearing balls.
Do you have the Motorcraft part number for the ball bearing alternative? I had a mechanic replace front strut assemblies twice with the plastic bearings and both sets began binding and making noise when turning within 100 miles of install. Hoping the ball bearing version is the fix.
peterk9
Staff member
Moderator
Callsign
VE3
RSNovi
MI
17 Limited 4WD
After 170k on my 2011 I am in need of another set of strut bearings. Looks like they only last about 80k.
S Symptoms of bad front strut bearings? Stock 2011 - 2019 Ford Explorer Discussion 29
M Wheel Bearings and Front Strut Mounts Worn Stock 2011 - 2019 Ford Explorer Discussion 22
R Front strut replacement 2013 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 4
S Front strut mount arrow Stock 2011 - 2019 Ford Explorer Discussion 5
B Confusion on front upper strut bracket part numbers - 2012 Stock 2011 - 2019 Ford Explorer Discussion 7
H Front Strut Rubber Boots Stock 2011 - 2019 Ford Explorer Discussion 2
M Uneven front pad wear? Stock 2011 - 2019 Ford Explorer Discussion 5
A 2012 Ford Explorer XLT Front Suspension Clunking Noise Stock 2011 - 2019 Ford Explorer Discussion 17
B Popping/grinding noise coming from under the front end when steering left or right Stock 2011 - 2019 Ford Explorer Discussion 4
F New member...ting/pop/click noise-front half shaft 2015 Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 10
G need help with front assist parking camera Stock 2011 - 2019 Ford Explorer Discussion 1
B 2014 Ex. Sport - $1,600 for front brakes and LCA bushings? Stock 2011 - 2019 Ford Explorer Discussion 12
E labor units about front apron panels replacement Stock 2011 - 2019 Ford Explorer Discussion 11
B Heated and Cooled Front Seats Stock 2011 - 2019 Ford Explorer Discussion 2
J Correct separator tool for ball joint @ lower control arm(front) Stock 2011 - 2019 Ford Explorer Discussion 5
B Front Washers Stopped Working Stock 2011 - 2019 Ford Explorer Discussion 12
B 2014 Limited Driver Side Front Window Inoperative Stock 2011 - 2019 Ford Explorer Discussion 0
A Front seat movement when using keypad to unlock Stock 2011 - 2019 Ford Explorer Discussion 4
L Why the tiny "cup holder" in front center console? Stock 2011 - 2019 Ford Explorer Discussion 13
K 2011 Banging noise in front, need help Stock 2011 - 2019 Ford Explorer Discussion 14
D 2015 Sport - Non HD Front Pads....? Stock 2011 - 2019 Ford Explorer Discussion 3
R Recall 19S17 and front alignment q's Stock 2011 - 2019 Ford Explorer Discussion 25
ddaniel13 2019 Limited cooled front seats Stock 2011 - 2019 Ford Explorer Discussion 9
K Static in front speakers Stock 2011 - 2019 Ford Explorer Discussion 7
J 2013 limited front exhaust pipe break (by flex joint), what to do... Stock 2011 - 2019 Ford Explorer Discussion 10
B Front end damage ? Stock 2011 - 2019 Ford Explorer Discussion 12
G Explorer 2013 front driver side louver handle cap Stock 2011 - 2019 Ford Explorer Discussion 8
J Rattle coming from under front of vehicle Stock 2011 - 2019 Ford Explorer Discussion 20
W 2018 Ford Explorer Damaged Front Camera Stock 2011 - 2019 Ford Explorer Discussion 6
Bobs2018Explorer 2018 Explorer XLT - Front Tow Recovery Hook? Stock 2011 - 2019 Ford Explorer Discussion 20
N Adding front parking sensors Stock 2011 - 2019 Ford Explorer Discussion 4
J 2013 explorer XLT front caliper suspension bushings Stock 2011 - 2019 Ford Explorer Discussion 3
K Front Passenger Axle Seal Leak Stock 2011 - 2019 Ford Explorer Discussion 2
B Front & Rear cameras shortcomings Stock 2011 - 2019 Ford Explorer Discussion 3
N 2016 front door 6x9 mounting depth Stock 2011 - 2019 Ford Explorer Discussion 1
S Should I remove the "Explorer" front hood emblem?? Stock 2011 - 2019 Ford Explorer Discussion 5
B Front end clunk - even in park Stock 2011 - 2019 Ford Explorer Discussion 4
I 2017 explorer front right axle leak Stock 2011 - 2019 Ford Explorer Discussion 14
R 2014 front windshield defogger is forced air only? Stock 2011 - 2019 Ford Explorer Discussion 2
S 2014 Sport - Burning Smell in front Stock 2011 - 2019 Ford Explorer Discussion 6
M 2016 Explorer Front End Wiring/Plug Help Stock 2011 - 2019 Ford Explorer Discussion 3
P External Front Lamps always on? Stock 2011 - 2019 Ford Explorer Discussion 5
realscot2 Front End thunk Stock 2011 - 2019 Ford Explorer Discussion 6
D Intermittent Front-End Hum - 2014 XLT Stock 2011 - 2019 Ford Explorer Discussion 2
E Front Rear Tire Wear Question Stock 2011 - 2019 Ford Explorer Discussion 2
D Side to side bar under the back of front seat? Stock 2011 - 2019 Ford Explorer Discussion 5
Jon M Right front door rattle Stock 2011 - 2019 Ford Explorer Discussion 6
M Front axle seal is leaking ... can't find part Stock 2011 - 2019 Ford Explorer Discussion 16
T Front left coil spring movement Stock 2011 - 2019 Ford Explorer Discussion 8
L Automatic lift gate & front suspension squeak! Stock 2011 - 2019 Ford Explorer Discussion 6
Similar threads
