Road Dog5398
- January 2, 2007
- Kingsport, Tn.
Hi All, I've got a 91 Explorer that leaks fuel every now and then. It normally does this at the first start of the day. It starts fine and runs fine, then we get a raw fuel smell. If we look under the vehicle its dripping fuel off the back center of the engine. If we shut it off and restert it after a couple of minutes it doesn't lesk anymore that day. It might do it again the next day or it will work fine for a while then do it again. I have checked for damaged lines and obvious signs of leakage to no avail. The check engine lihgt does not come on in conjunction with this problem. If it helps any its a plain jane manual everything, with a 4.0 V6. As I said it doesn't seem to effect the proformance of the vshicle at all. So I am baffled. Thanks in advance for any and all help you all can give me. Jim
