joshua5438
- March 16, 2018
- Easley, SC
- 2015 Sport
I have been having an issue with my 2015 Sport where it will cut out when you put the pedal to the floor. I had a mechanic look at it and he claimed it was the spark plugs. I put new plugs in it when I installed the Gearhead tuner about 6 months ago so I really doubted that was it. I have now had it throw a code twice. Both time it has been an air temp of 100 degrees. The car will completely loose all throttle response and start to idle like its missing on two cylinders. Shut the engine off and let it sit for about 10 minutes and it will start up and run normal. The code is a P0087 - Fuel Rail/System Pressure - Too Low. With all of this said, I believe it to be the fuel pump. Until now, I had no idea it had three fuel pumps. Has anyone else had a similar issue and correctly identified which pump is going out? I feel it would be the high pressure pump mounted on top of the engine but not sure.
