Fuel Pump | Ford Explorer Forums
Fuel Pump
TheBeaves26
2001 Ford Explorer Sport
I have a 2001 Ford Explorer Sport. It won't start. Cant hear fuel pump cycle when key is in run. If anyone can tell me which fuses and relays need to be checked will be very thankful. And if worst case scenario a fuel pump at around $50
under your hood is the fuse, relay box...#9 fuse and #5 relay
here's your owners manual
http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/01expog1e.pdf
You have 2 one in the vehicle and one under the hood, it'll be a black plastic box with a cover on it, should be near your brake master cylinder...
If it's not the fuse or relay. try the inertia switch...
What does your box look like?
If you click the link associated with that image, it appears that 50B is your fuel pump relay.
