FUTURE EXPLORERS TO FEATURE FUEL-EFFICIENT ELECTRICAL ASSIST | Ford Explorer Forums
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL '20 ST
Callsign
AB7FH
DETROIT, January 9, 2001 - Ford Motor Company's next-generation Explorer will achieve break-through levels of fuel economy and offer more high-tech comfort and convenience features by utilizing a new high voltage electrical system and a technology that automatically shuts the engine off when the vehicle is stopped.
Known in the industry as an integrated starter-generator or ISG, this start-stop engine technology will debut in the Ford Explorer soon after the Escape hybrid electric vehicle (HEV) in 2003. But unlike the Escape HEV - a full hybrid that uses an electric motor for propulsion and a 4-cylinder gasoline engine - the ISG 42-volt Explorer will rely on an efficient 6-cylinder gasoline engine with electric assist. The integrated starter-generator, as its name applies, replaces both the conventional starter and alternator and integrates starting and generating in a single electric machine.
The integrated starter-generator will allow the engine to automatically shut off when the Explorer is stopped, such as at a traffic signal, and then immediately start again when the need for power is anticipated. The transition from stop to start will be completely transparent to the driver. This start-stop feature will help the Explorer achieve fuel economy numbers unheard of in a vehicle that provides the room, off-road toughness and power that America's best-selling SUV delivers.
This start-stop feature debuted in Ford Motor Company's P2000 HEV concept car and makes its first production application debut on the Escape HEV, a concept of which was shown last week at the Los Angeles International Auto Show. The Escape HEV will deliver about 40 miles per gallon in urban driving, yet deliver acceleration performance similar to an Escape equipped with a V-6 engine.
"The fuel-efficient technology in the future Explorer will continue our commitment to our customers and to society to develop the most capable and advanced SUVs on the planet," said Gurminder Bedi, vice president - Ford Truck. "The fuel economy gains we will achieve with this technology will set new standards for SUVs without sacrificing the capabilities customers expect."
Coupled with this ISG system on the Explorer will be a regenerative braking system and a more powerful electrical system that delivers 42 volts rather than the current 12 volts. The regenerative braking system captures energy generated from the braking system to help recharge the vehicle's 42-volt battery, which in turn provides the engine with a slight acceleration boost at startup. A smaller 12-volt battery, roughly the size of a motorcycle battery, will be used to operate standby items such as emergency flashers and radio.
Every year, automobiles require more electrical power for new vehicle features. Items such as electronically heated seats, entertainment and navigation systems are already reaching the upper limits of what the current 12-volt systems can handle. It is a system that was never designed to handle increasingly complex and demanding vehicle electrical requirements.
About one mile of wiring will go into the electronic intensive car of the near future. At 12-volts, that wiring has to be exceptionally thick to handle 3 kilowatts of current; and weight becomes an issue. With a 42-volt system, wiring bulk is reduced because higher-voltage lowers the electrical current, enabling narrower gauge wiring.
Ford Motor Company, like many in the industry, favors an initial dual-voltage system. The 42-volt core system would be supplemented by a 12-volt subsystem to run traditional low-voltage devises such as lamps and radios. This dual-voltage system eliminates the need for a costly redesign of the intricate, on-board electronic system used today, while retaining positive 12-volt attributes, such as the extension of filament life at lower voltages.
The 42-volt electrical system allows the company to more quickly satisfy customer demands for improved comfort and convenience items, including the ability to offer a 110-volt AC outlet that would allow customers to operate power tools from their vehicles. This high-voltage, high-powered electrical system also paves the way for advanced technology items such as energy-efficient electromechanical valvetrain actuation, electric superchargers and advanced active suspension systems. With electronically actuated valves, valve timing could be easily varied because it would be under computer control. The end result would be more horsepower from a smaller displacement engine that runs considerably cleaner.
The actions of all these subsystems are coordinated by a vehicle system controller that builds upon Ford Motor Company's drive-by-wire experience gained through its Aston Martin programs, Jaguar S type and Ford's diesel engine equipped F-Series, Transit, Mondeo and Focus. The use of an integrated starter-generator on Explorer helps support Ford Motor Company's Cleaner, Safer, Sooner declaration to deliver vehicles that produce fewer emissions and improved fuel economy, far exceeding any regulatory requirements.
Courtesy www.blueovalnews.com
Sounds like a great use of technology... but what are all of the hippies going to ***** about when SUV's start getting the same (or better) mileage than an Accord?
They will probably ***** about something else :D
That will be so cool when they are released, Rick :)
Pretty cool.
I think my VW could really benefit from an auto on/off feature.
This seems like it would be a pain in the ass for the mechanical, do-it-yourselfer, modification, standpoint.
But I guess the classic muscle car days are getting further and further in the past. :(
duh.
Why? You'll still be able to do motor mods, and there will still be a 12V parallel electrical system.
"The integrated starter-generator will allow the engine to automatically shut off when the Explorer is stopped, such as at a traffic signal, and then immediately start again when the need for power is anticipated. The transition from stop to start will be completely transparent to the driver. This start-stop feature will help the Explorer achieve fuel economy numbers unheard of in a vehicle that provides the room, off-road toughness and power that America's best-selling SUV delivers."
I hope that is one hella strong starter. I can only imagine what it will cost to replace:eek: I suppose you would have to do a brake torque to make sure the engine was turned on before racing the Grand Cherokee next to you. Could you imagine all the starting and stopping the engine would do while four wheeling:eek:
Hopefully they'd put in an override so you can disable the start/stop feature.
Explorer Hybrid
I tried out a hybrid Honda Civic and it was pretty nice (for a car). Eventually all cars are going to the 42 volt electrical system. Still I have mixed reactions. The hybrids will certainly cost more.
I think that Ford is doing the right thing. There is increasing pressure from the environmental lobby and politicians to mandate higher c.a.f.e. and emisions standards. This, plus potential fuel shortages/price increases could kill the SUV market, so Ford really has no choice in developing the hybrid Explorer and Escape.
Even, so it will be a challenge for Ford and us. I just hope the system is perfected before it is marketed. Remember the Oldsmobile diesel or the infamous Cadillac 8/6/4 cylinder engine?
I'm skeptical about 42 volts. It will make the vehicles electrical system work more efficiently, but what about our 12 accessories like ham radio gear? I don't think they will run well on the equavalent of a motorcycle battery. (The 12 V battery in the Honda hybrid is really tiny.) WE might have to add auxiliary deep cycle batteries. I can forsee all kinds of problems trying to jump start either a 12 V or 42 volt system.
Time will tell.
Bwana Bob in NJ
imagine the possibility of hooking up your 1,000 watt class D amp (@ 14.4) to a 42 volt electrical system. of course it would blow up- but sooner or later they will innovate and it will be incredible
hell if i get a car that runs 42 i'll be trying to do just that- think of the name you could make for yourself and your company if you started offering amps that could work at that voltage and provide staggering power numbers.
Various companies will also be very quick to supply 42V > 12V transformers.
So far it's 5 years later, and what happened to all of this that Ford promised us? I'm sure that they are still planning on coming out with it. Some things are already coming to the market, like 42 volt systems, integrated starter/alternator, and hybrid technology. What about all of this in the Explorer?
So in a panic stop would you lose your power steering? :eek:
Instead of having your accessories run off of the engine, you would have an electric pump provide boost pressure, or just have an electric rack and pinion. TRW makes this. In 1993 I designed an electronic system (with an electric pump) to work on my 88 van. I removed the mechanical pump, and replaced it with an electric/hydraulic pump. I've also designed a couple of control modules to turn the pump on and off. The latest one uses 3 printed circuit boards, and a steering column mounted reed switch sensor with a magnet. I also integrated into it a few other features, like a variable time delay, diagnostics, anti false trigger circuitry, and test buttons to initiate the self diagnostic. I originally wanted to get it patented (this was before the big companies had this), but found out that it would cost about $20,000! Another private company in Detroit was interested in it, but just wanted to steal the idea. I was very careful not to give him more information than what I thought was necessary. I think his company eventually went out of business.
