scootr2200
- July 4, 2005
- Western NC
- 1986 Ranger
Well, after long and seriuos though, I'm going to do a SAS on my '86 Ranger.
Origionally I had thoughts of a D44/9" on radius arms but then I started thinking that I might not be able to accomplish enough lift to clear 38"+ tires and still be able to be abused with a Cummins 4bt motor that I'd like to put in.
So now I'm thinking that a D60 with leafs is my best option to be able to withstand the torque and tire size that I would like to have.
Is there a leaf spring out there that I can use to achieve enough lift for 38+ tires and not droop when the diesel is put in (weighs a little more then a big block gasser) and not have to have hangers as long as my legs?
I assume that I cannot move in my spring perches, so my hangers will have to be spaced out. Could I just use a design that's used for hanger flips? And for the front, I realize a crossmember will have to be setup, does it have to hang low to keep the pinion angles correct? I would prefer not to have it kill approach angles and it be a unsightly eye sore. (I will also install a 3" body lift so that I can set the motor further back without as many clearance issues)
Another, how do I know how to setup the correct pinion angles and still keep steering angles right? Cut and turn?
Which rear axle is good to match with a D60 front? I though of a Sterling 10.5.. or a D60?
What steering box could I use and would a hydrualic steering (or hyraulic assist) be a best bet?
How wide is a ball joint style D60 (as I don't think I can find a kingpin style)? And how much wider is it then a FW D44 front?
I will be designing and welding my own brackets and crossmembers... I hope that I can get with my local college that has a wonderful egineering department equiped with lazer and waterjet cutting machines and have them cut the brackets.
Any help would be great and I appreciate any that I do get.
Mickey
Mickey
